lw187
Aug 18, 2020Guide
RBR850 and RBS850 3.2.16.6 Connection Problems (iOS app, 10.0.0.1, and orbilogin.com)
Updated Router and two satellites to 3.2.16.6. All seemed to be ok. Added to wired satellites today. Changed names just fine. All seemed to be ok. At some point connectivity via the orbi app...
- Aug 18, 2020
Believe it or not, just turned the router off. Turned it back on. And eveyrthing visible again. Sorry for the trouble, ty for the prompt reply
lw187
Aug 18, 2020Guide
Aug 18, 2020Guru - Experienced User
Ok, thanks for letting us know. Glad that was all that was needed. Will keep that in mind.
I presume your using the DMZ on the FIOS router for the RBR?
Enjoy. :smileywink:
