Dapone
Mar 16, 2024Tutor
RBR850 and RBS850 can not connect
Hi, Since 2022 using the RBR850 with 2 satellites working well and both using the latest firmware. I bought recently 3 extra satellites RBS850 to connect to existing network but i am unable to connec...
- Mar 16, 2024
If you type that ip address into the address bar, it'll take you to the log in page for the satellite.
michaelkenward
Mar 16, 2024Guru - Experienced User
Dapone wrote:
The helpdesk from Netgear tells me to update the firmware on my recently purchased satellites but since i can not connect i do not know how.
You can connect to the satellites without connecting them to the main router.
How do I check and manually update the firmware on my Orbi satellite? | Answer | NETGEAR Support
- DaponeMar 16, 2024Tutor
How do i do this?
I do not see them in my orbilogin.com
If i connect it direct to the router i can see it but can not do anything?
Also the link you send me i understand but since it is not visible in that page i can not do anything
