Dapone
Mar 16, 2024Tutor
RBR850 and RBS850 can not connect
Hi, Since 2022 using the RBR850 with 2 satellites working well and both using the latest firmware. I bought recently 3 extra satellites RBS850 to connect to existing network but i am unable to connec...
- Mar 16, 2024
If you type that ip address into the address bar, it'll take you to the log in page for the satellite.
Mar 16, 2024Guru - Experienced User
did you try updating the firmware with the satellite hardwired to the router?
- DaponeMar 16, 2024Tutor
How do i do this?
Hardwired means a network cable from new satellite to router? i did this but than i can not do anything or at least i do not know how to do it.
- plemansMar 16, 2024Guru - Experienced User
sorry, your photos are to small to see anything.
If its wired in and you have an iP address, you can use that to log into the satellite directly and update it.
Hi Plemans,
sorry for my lack of experience but how do i log in if i have the IP adress?
