CraigRichesNL
Feb 14, 2021Aspirant
RBR850 and RBS850 Daisy Chain where is the option?
Hi Community, I have 1 x RBR850 and 4 x RBS850 The RBR850 is on 1 far side of the house attached to my ISP's Router Modem(wifi disabled) and the RBS850 are at longer and longer distances from the R...
- Feb 22, 2021
ANd that is precose;y what I have done and the result is as I describe. 😊
Feb 22, 2021Guru - Experienced User
If you have the RBS placed out in a line, not start formation, from the RBR, then the first RBS that you need to turn on is the one closest to the RBR and wait for it to sync, then the next RBS closest to the 1st RBS, wait for it to synce, then so on out to the last RBS.
30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
CraigRichesNL
Feb 22, 2021Aspirant
- FURRYe38Feb 22, 2021Guru - Experienced User
Then if you open the Orbi app, and select on the Network Map icon, all the RBS should in be in a line and connected to each other and only the nearest one should be connected to the RBR.
- CraigRichesNLFeb 22, 2021Aspirant
Nope they are connected separately to the Router (RBR850) Maybe too many satellites in use?
Anyway, giving up now as it is obviously not going to work in Daisy Chain mode and there is no way to change that.
I'd turn OFF two RBS. Go with the other two RBS. Turn on RBS on and check the app. Them make sure the other RBS is farther out at a distance then turn it on.
You might try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
