OrbiOrNot's avatar
OrbiOrNot
Initiate
Mar 19, 2024
RBR850 and RBS850 wired backhaul kills satellite connection
I own the following Orbi devices:   1 RBR850 Router 3 RBS850 Satellites. Edgerouter V4 router CAT6E cabling from RBR to router and 2 RBS's. These have a home run connection to my router. AP mod...
  • OrbiOrNot's avatar
    OrbiOrNot
    Mar 20, 2024
    Thanks FURRYe38 .  You helped me figure it out!  I had checked this page https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System at least 10 times and was pretty sure that my config matched this:
    When I saw your post, I thought I might as well check my setup one more time.  It turns out I had plugged the cable into the yellow port on the router which is not how it should be set up.  It has to be one of the other ports,  So how did I end up this way?  I remember moving things around and I guess when I moved the router I inadvertently plugged the cable in the wrong port.
    I'm back to the wired backhaul connections working.  Thanks!
