cenolt100's avatar
cenolt100
Initiate
Jan 31, 2021
RBR850 APP and IP connection Difficulty
Hi,
I own an RBR850 and two satellites.  When I first bought the system the phone App and the browser interface (192.168.1.1) worked great, but now either interface takes about 60 seconds or more to connect ----- and sometimes they never are able to connect.  The computer I'm using to connect to the router is hardwired, so it's not as simple as a Wifi issue.  The App shows 10 devices connected, the web interface shows 22.  I rebooted the network, it still has trouble connecting.
Meanwhile, while these interfaces work terribly, the router is handling all of the traffic we can throw at it.  Firmware has been updated. That's not the problem either.
What is going on?
Thanks,
cenolt
1 Reply
