scamperpamela
Aug 30, 2021Star
RBR850 AX6000 System Startup Issues with DNS and browser refreshes
I am posting here because my problems and solution have ended up in a different discussion with a not obviously appropriate title. After the usual startup problems, I was having a consistent problem...
- Aug 30, 2021
I just had a browser refresh issue but am still going to mark this as solved as I'm guessing an occasional browser display will fail. At any rate, it appears much improved, and I am out of things to do to improve it, LOL!
scamperpamela
Aug 30, 2021Star
scamperpamela
Aug 30, 2021Star
...a few minutes later. The browser refresh problem is back with multiple sites, etc. I haven't a clue. Nothing else to try. I'll reboot everything. I can live with it, not sure it is related to anything here.
- FURRYe38Aug 30, 2021Guru - Experienced User
What browser are you using? Does this happen with MS Edge, FireFox or Opera?
Be sure to clear out all browser caches, close the browser then re-open.
- scamperpamelaAug 30, 2021Star
Will collect answers and get back here. On the Spectrum modem, there is no brand name. It has "Spectrum" inprinted in its black plastic case and a sticker. The stick has MAC addresses, S/N, "PC15", Factory id UDC 112120. In looking at the Spectrum site, I think it is a Spectrum DOCSIS 3.1 eMTA.
Probably a Hitron EV..something model. I think. :smileyembarrassed:
