Daveu
Sep 26, 2021Star
RBR850 backhaul out of sync
I recently upgraded to the RBR850. I wanted to keep using my older satellites (2 RBS20 and 1 RBS50). My RBS850 is wifi. All other satellites are on lan with a switch between the router and them. ...
Daveu
Sep 27, 2021Star
Sorry for the delay.
There are two switches
1) Trendnet Teg-S50g
2) TP Link TL-SG1005D
Currently I have the each switch connected to the RBR850 and a satellite connected to each switch.
I’ve unplugged all the satellites and plugged them directly into the R850 by lan. Restarted everything and backhaul status is still showing up as out of sync.
IP is Rogers in Canada using Hitron Coda-4582U modem if that matters
Sep 28, 2021Guru - Experienced User
How long are you giving the status before checking it after you had the RBS directly connected to the RBR? I would have waited 5-10 minutes.
Try factory resetting the RBS, then powering OFF the RBS fully for 24 hours, then reconnect...
