pnicolas
Jun 12, 2022Aspirant
RBR850 bad ping
Hello I just got an RBR850 with one router and one satellite. The bandwidth is far more better than the previous TP-Link I got except for the ping time. RBR850 router is at the same place th...
Jun 12, 2022Guru - Experienced User
What are you pinging? The RBR itselt? Ping the ISP modem thru the RBR? Pinging the RBR to the RBS? RBS to the RBR?
How are you pinging? Wireless or wired connection? Wired connection is preferred.
CAT6 LAN cable is recommended.
Show a screen capture of what your seeing here in a post.
pnicolas
Last FW on RBR and RBS : V4.6.3.16_2.0.51
with factory reset after upgrade
This tests with a MacBook but tests with Raspberry Pi or PC are the same.
RBR ping (from the room with RBS) :
\ping 192.168.1.72 -c 4
PING 192.168.1.72 (192.168.1.72): 56 data bytes
64 bytes from 192.168.1.72: icmp_seq=0 ttl=64 time=8.584 ms
64 bytes from 192.168.1.72: icmp_seq=1 ttl=64 time=37.095 ms
64 bytes from 192.168.1.72: icmp_seq=2 ttl=64 time=7.193 ms
64 bytes from 192.168.1.72: icmp_seq=3 ttl=64 time=18.186 ms
RBS ping (in the same room)
\ping 192.168.1.73 -c 4
PING 192.168.1.73 (192.168.1.73): 56 data bytes
64 bytes from 192.168.1.73: icmp_seq=0 ttl=64 time=15.221 ms
64 bytes from 192.168.1.73: icmp_seq=1 ttl=64 time=3.142 ms
64 bytes from 192.168.1.73: icmp_seq=2 ttl=64 time=51.166 ms
64 bytes from 192.168.1.73: icmp_seq=3 ttl=64 time=8.335 ms
ISP router from the same room RBS :
\ping 192.168.1.1 -c 4
PING 192.168.1.1 (192.168.1.1): 56 data bytes
64 bytes from 192.168.1.1: icmp_seq=0 ttl=64 time=166.326 ms
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=7.577 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=36.089 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=58.130 ms
ISP router is a french LiveBox with fiber 2*1 Gbps
test speed from RBR which is cable cat6 connected :
937.36 Mbps - 604.23 Mbps
Tests from a Raspberry connected to the LiveBox :
ping 0ms Download : 937 Mbps Upload : 598 Mbps
Again, 1/2 ms ping with same tests with TP-Link but bad bandwidth with TP-Link
