pnicolas
Jun 12, 2022Aspirant
RBR850 bad ping
Hello I just got an RBR850 with one router and one satellite. The bandwidth is far more better than the previous TP-Link I got except for the ping time. RBR850 router is at the same place th...
Jun 12, 2022Guru - Experienced User
How are you pinging? Wireless or wired connection? Wired connection is preferred.
CAT6 LAN cable is recommended.
What are your wired pings from the PC to the RBR?
WHat are you wired pings from the PC to the RBR with ALL RBS turned OFF?
What are your wirelesss pings from the PC to the RBR with ALL RBS turned OFF?
pnicolas
all wireless pinging except for the RBR to the ISP router
