steel2
Sep 01, 2022Aspirant
RBR850 Blocking Legrand Hub?
Setup: ISP connected to Orbi. Firmware V.4.6.9.11 Orbi connected to ethernet switch. About 20 wired devices connected. Orbi has another 15 wireless devices. Legrand (Smartlight) hub is wired to swit...
- Sep 01, 2022
Something on that switch maybe blocking. That a managed switch so could be anything. Something to contact TP-Link about.
Or swap that out for a non managed switch between the RBR and these devices.
Sep 01, 2022Guru - Experienced User
What is the Mfr and model# of the lan switch thats connected to the RBR?
Can you connect the device directly to the back of the RBR and see if same thing happens?
- steel2Sep 01, 2022Aspirant
First; Connecting directly to Orbi did work with the new hub - thanks! I had tried that with the old one, but would not work, so assume it was faulty. Now, all ipads and iphone works too!
The switch is TP Link TL-SG1024DE.
Not sure of ISP modem as it is in a locked wall box outside
Still curious, why did it not work through the TP-Link?
Thanks again!
- FURRYe38Sep 01, 2022Guru - Experienced User
