jefvandejumenas
Sep 03, 2022Aspirant
RBR850 can not remove item from acces list
Dear members, Excuses for my not so correct English. I am not a native speaker or writer ... I own a RBR850. In the tab "ADVANCED"/"SECURITY"/"ACCES CONTROL" it is impossible to remove an item from...
- Sep 06, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sep 03, 2022Guru - Experienced User
- jefvandejumenasSep 03, 2022Aspirant
I have not done a factory reset, because for the rest is everything working.
I update my NAS frequently but factory reset was needed.
Maybe it is necessary if you have serious trouble.- jefvandejumenasSep 03, 2022Aspirant
factory reset was NOT needed. Sorry
Btw I am in Advanced mode and in acces control- jefvandejumenasSep 06, 2022Aspirant
Maybe I did not explain it so well.
Before The Orbi system I had Cisco, Linksys and Belkin. I could delete items out of the networksystem. I did all the updates and never had to reinstall the system again. I have to say that most of the items were connected wired. Some were wireless.
Due to a move to another house I had to use a wireless system.
Right now I got more than 15 devices in the network. Only a few are wired. Those that are close to the satellites.
Is there some golden tip that I can delete items out of the list of allowed devices not currently connected to the network without having to do a total reset?
Any working advice is welcome.
Just noticed that via the webinterface I was able to delete items from list 2. Can someone explain why this is?
