jefvandejumenas
Sep 03, 2022Aspirant
RBR850 can not remove item from acces list
Dear members, Excuses for my not so correct English. I am not a native speaker or writer ... I own a RBR850. In the tab "ADVANCED"/"SECURITY"/"ACCES CONTROL" it is impossible to remove an item from...
- Sep 06, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
jefvandejumenas
I have not done a factory reset, because for the rest is everything working.
I update my NAS frequently but factory reset was needed.
Maybe it is necessary if you have serious trouble.
jefvandejumenas
factory reset was NOT needed. Sorry
Btw I am in Advanced mode and in acces control
- jefvandejumenasSep 06, 2022Aspirant
Maybe I did not explain it so well.
Before The Orbi system I had Cisco, Linksys and Belkin. I could delete items out of the networksystem. I did all the updates and never had to reinstall the system again. I have to say that most of the items were connected wired. Some were wireless.
Due to a move to another house I had to use a wireless system.
Right now I got more than 15 devices in the network. Only a few are wired. Those that are close to the satellites.
Is there some golden tip that I can delete items out of the list of allowed devices not currently connected to the network without having to do a total reset?
Any working advice is welcome.
Just noticed that via the webinterface I was able to delete items from list 2. Can someone explain why this is?- jefvandejumenasSep 06, 2022Aspirant
Problem solved.
Deleted cache, deleted apps (both on pc and phone), deleted IP's.
Reinstalled them again (no factory reset and no new setup from scratch since last update).
So far everything is working again.
Thanks for the reactions.
jefvandejumenas- FURRYe38Sep 06, 2022Guru - Experienced User
Enjoy. 📡
