jefvandejumenas
Sep 03, 2022Aspirant
RBR850 can not remove item from acces list
Dear members, Excuses for my not so correct English. I am not a native speaker or writer ... I own a RBR850. In the tab "ADVANCED"/"SECURITY"/"ACCES CONTROL" it is impossible to remove an item from...
- Sep 06, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
jefvandejumenas
Sep 06, 2022Aspirant
Problem solved.
Deleted cache, deleted apps (both on pc and phone), deleted IP's.
Reinstalled them again (no factory reset and no new setup from scratch since last update).
So far everything is working again.
Thanks for the reactions.
jefvandejumenas
Sep 06, 2022Guru - Experienced User
Enjoy. 📡
