popechild2
Jul 12, 2024Guide
RBR850 Can't get internet from Xfinity xFi Gateway
Hi, I've spent about 9 hours on this today, so really hoping someone here has some ideas to break the logjam! I've got an RBR850 and 5 RBS850's. FW 7.2.6.31. I've been using them for a few years ...
CrimpOn
Jul 14, 2024Guru - Experienced User
popechild2 wrote:
This would seem to indicate that the Orbi router is not connected to the xFi box at all. (WAN port status is blank.)
popechild2
Jul 14, 2024Guide
Yes, that's what's strange to me. Because the xFi is definitely connected to the Orbi and it's definitely connected on the yellow Wifi WAN port. And the Connected Devices list shows the MAC address of the modem, so it's "seeing" the modem somehow, which again is connected to the yellow WAN port.
Also, nothing is connected to the LAN1 port, but there's activity showing there.
- CrimpOnJul 14, 2024Guru - Experienced User
I am sometimes too fixated on terminology. In this discussion, the term modem can refer to
- The Netgear CM1100 modem, or it can refer to
- The xFi box? (which specific xFi is this?)
At no time are both the CM1100 and the xFi operating at the same time?
- popechild2Jul 14, 2024Guide
After from the brief period of time that the Xfinity agent was trying to help me swap back to the CM1100, which is when all this trouble started, I have been exclusively using the xFi XB8 Gateway. That's the modem I'm having all the trouble with.
Thanks for being patient. Is there a specific reason to put the XB8 into Bridge Mode?
