popechild2
Jul 13, 2024Guide
RBR850 Can't get internet from Xfinity xFi Gateway
Hi, I've spent about 9 hours on this today, so really hoping someone here has some ideas to break the logjam! I've got an RBR850 and 5 RBS850's. FW 7.2.6.31. I've been using them for a few years ...
popechild2
Jul 15, 2024Guide
All satellites are disconnected from power and ethernet.
I’ll update if there’s any further guidance after talking to support.
RedsonRising
Aug 15, 2024Aspirant
Any updates yet?
- popechild2Aug 15, 2024Guide
Support wasn't any help, but I eventually bought a used RBR850 since I couldn't figure out anything else to try and the new (used) one connected right away. So clearly some sort of hardware problem, though what exactly it was I couldn't say. The ports showed activity, the wifi worked, it just somehow either wouldn't receive or pass through the internet signal from the modem. And it was out of warranty, so nothing I could really do but buy a replacement.
- FURRYe38Aug 15, 2024Guru - Experienced User
Has anyone tried a stand along modem? XF supports BYOM so would be an alternative and something to try. ISP Gateways can be problematic with external WiFi router systems. I now that others have used NG CM series modems with this ISP and they work well.
- donawaltAug 15, 2024Mentor - Experienced User
It sounds like replacing the RBR850 fixed the problem. I assume you are not in warranty period to get it replaced, but you bought another 850 anyway.
FWIW I have a NG CM3000 FURRYe38 and it works great, but the XB8 (bridge mode) -> 850 seems necessary to avoid being charged for going over the data cap (this doesn't exist in the northeast, but does everywhere else in the country with Comcast).
So it sounds like problem solved now with new 850? Or are there other outstanding issues still?
