Z42985's avatar
Z42985
RBR850 Changing Guest LAN IP subnet / Guest Wireless subnet- The IP address conflicts with the Guest
When I attempt to change my LAN subnet to 192.168.2.0 I get this error message. "The IP address conflicts with the Guest LAN IP subnet. Please enter a different IP address." So how do I change the...
  • ekhalil's avatar
    ekhalil
    Oct 27, 2019
    If you like you can go for changing the guest network reserved address range using telnet commands as follows:
    • nvram set lan1_ipaddr=192.168.3.1
    • nvram set lan1_gateway=192.168.3.1
    • nvram set lan_ipaddr2=192.168.3.1
    • nvram set dhcp_start2=192.168.3.2
    • nvram set dhcp_end2=192.168.3.254
    • nvram commit
    • reboot the router
    • Set the LAN IP address to 192.168.2.1 in the Orbi web GUI under >> ADVANCED >> Setup >> LAN Setup
