vksvicky's avatar
vksvicky
Follower
Jul 05, 2020
RBR850 Configuration Issue
I have RBR850 with Firmware V3.2.15.25_1.3.15, here are my issues?
1. I could never get the Android app to recognise the device and connect. I updated the name of the device (vORBI11) to something other than the default (RBR850), and still the app won't recognise the device, I have to connect via browser using an IP
Is there a way to solve this?
2. I am using Sky as my broadband provided and had put the Orbi on Router mode, is this correct?
3. When I change WAN Preference from Internet Port to WAN aggregation, I don't have Internet, is this the correct setting?
4. I have enabled Remote Management and still I cannot connect to the Orbi via Remote Management. Anyone know why?
1 Reply
  • FURRYe38's avatar
    Please post about this in the Orbi app forum:
    https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Does your ISP modem support Aggregation? If not then you can't use LAG.
    See #2 response above.
