jphenrick18
Jul 16, 2020Follower
rbr850 daisy chaining
hello
i have just upgraded from rbr50 and cannot find how to turn off daisy chaining - not in the wireless settings options....
Few of us who participate in this forum have any experience with the new "AX" series Orbi products*. On the WiFi5 residential product that we have, Daisy Chain is on the Advanced Tab, Advanced Settings, Wireless Settings.
If your Orbi does is different, you will probably get good advice by posting on the AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
*For example, I have no idea if Daisy Chain on/off is even an option on the AX product, as I have never touched one. There is probably a User Manual on the Netgear support site.
Daisy Chain is enabled and working by default on Orbi AX. Placement will be key if you need it to work or not.
