AP4120
Jun 19, 2020Follower
RBR850 debug screen No Telnet Option
Hello All, I have a Orbi RBR850 that works great however, I need to seperate out the 2.5 & 5 bands and name them different so some of my older devices will connect to 2.5 & not time out trying to con...
Jun 19, 2020Guru - Experienced User
Please post about this over in the Orbi AX Forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
AP4120 wrote:Hello All, I have a Orbi RBR850 that works great however, I need to seperate out the 2.5 & 5 bands and name them different so some of my older devices will connect to 2.5 & not time out trying to connect to the 5 since they share the ssid name
I came across a 192.168.1.1/debug.htm login to enable telnet so I can command line the script to fix this, however the telnet check box doesnt exist on that page. There is only debugging options and log scanning options. Does anyone know how I can turn on telnet services on this unit? Or is there a different page with the new firmware of these devices? Its currently on a 3.15.2 I believe.
Thanks so much
AP
