AP4120
Jun 19, 2020Follower
RBR850 debug screen No Telnet Option
Hello All, I have a Orbi RBR850 that works great however, I need to seperate out the 2.5 & 5 bands and name them different so some of my older devices will connect to 2.5 & not time out trying to con...
Modernz
Sep 22, 2020Aspirant
I found that “downgrading” to the oldest firmware on the support page allowed me to enable telnet. Access was still intact after re-upgrading to the latest firmware. Hope that helps.
- FURRYe38Sep 22, 2020Guru - Experienced User
telnet can be enabled on current v6 FW as well using the telnetenabler from the git repo that out on the net.
Modernz wrote:
I found that “downgrading” to the oldest firmware on the support page allowed me to enable telnet. Access was still intact after re-upgrading to the latest firmware. Hope that helps. - Lancelot218Apr 12, 2021Aspirant
I would like to confirm with you, the oldest version you mentioned is 3.1.5.23?
Also would you please list out the procedure of downgrading the firmware?
such as, downgrade RBR/RBS first?
Many thanks.
- FURRYe38Apr 12, 2021Guru - Experienced User
If you downgrade, downgrade the RBS first then RBR lastly. Same FW update proceedures for manually updating FW on Orbi.
May I also have the version number which still have the telnet enable option?
