AP4120
Jun 19, 2020Follower
RBR850 debug screen No Telnet Option
Hello All, I have a Orbi RBR850 that works great however, I need to seperate out the 2.5 & 5 bands and name them different so some of my older devices will connect to 2.5 & not time out trying to con...
parisv
Oct 12, 2020Tutor
when do you get the mac address for the lan port from?
does this mean I need to be connected to the router via ethernet rather than wifi to run the script?
Mikey94025
Oct 12, 2020Hero
parisv wrote:when do you get the mac address for the lan port from?
The MAC address for the LAN port is also displayed on orbilogin.com / Advanced tab, under Router Information. The MAC address for the upstream internet connection is under Internet Port.
- parisvOct 12, 2020Tutor
ok I've tried the command from cmd in admin mode exactly the way the readme says it should run and telnet is still not working.
is it possible to get an output of the python script to see if it's actually working?
- FURRYe38Oct 12, 2020Guru - Experienced User
If the script executed with out any errors, then telnet should be working.
Can you access the telnet using teraterm or putty at all? The one time I did it it worked for me on my 8 series RBR.
- Mikey94025Feb 24, 2021Hero
parisv wrote:ok I've tried the command from cmd in admin mode exactly the way the readme says it should run and telnet is still not working.
I noticed the telnet backdoor stopped working for me in January: https://community.netgear.com/t5/Orbi/Telnetenable-on-Orbi-RBR50-Firmware-2-7-0-70/td-p/1983293. The telnetEnable tool doesn't work anymore for my RBR850 or RBR50 with the latest firmware versions.
- FURRYe38Feb 24, 2021Guru - Experienced User
RBR50 telnet works with just enabing telnet under the debug.htm. The telnet enabler isn't needed.
Unfortunately for the RBR850 on v12 FW, enable telnet using the telent enabler isn't working. :smileysad:
