AP4120
Jun 19, 2020Follower
RBR850 debug screen No Telnet Option
Hello All, I have a Orbi RBR850 that works great however, I need to seperate out the 2.5 & 5 bands and name them different so some of my older devices will connect to 2.5 & not time out trying to con...
parisv
Oct 12, 2020Tutor
ok I've tried the command from cmd in admin mode exactly the way the readme says it should run and telnet is still not working.
is it possible to get an output of the python script to see if it's actually working?
Oct 12, 2020Guru - Experienced User
If the script executed with out any errors, then telnet should be working.
Can you access the telnet using teraterm or putty at all? The one time I did it it worked for me on my 8 series RBR.
