AP4120
Jun 19, 2020Follower
RBR850 debug screen No Telnet Option
Hello All, I have a Orbi RBR850 that works great however, I need to seperate out the 2.5 & 5 bands and name them different so some of my older devices will connect to 2.5 & not time out trying to con...
Lancelot218
Apr 12, 2021Aspirant
I would like to confirm with you, the oldest version you mentioned is 3.1.5.23?
Also would you please list out the procedure of downgrading the firmware?
such as, downgrade RBR/RBS first?
Many thanks.
Apr 12, 2021Guru - Experienced User
If you downgrade, downgrade the RBS first then RBR lastly. Same FW update proceedures for manually updating FW on Orbi.
- Lancelot218Apr 12, 2021Aspirant
May I also have the version number which still have the telnet enable option?
- FURRYe38Apr 12, 2021Guru - Experienced User
Try V3.2.15.25_1.3.15
Sorry for so many questions, I would like to ask one more question, if I change the SSID for 2.4G in V3.2.15.25_1.3.15, and the RNR will auto update to the latest version, so will my configuration still applied after the RBR auto update?
- brwattersJul 08, 2021Aspirant
I have found that firmware v3.2.18 does not appear to allow you to down grade firmware any longer as it warns you are doing so and ONLY allows you one option of "NO" to proceed.
This is really starting to go the wrong direction with firmware updates.. I purchased these as they had more control over network config than Googles WiFi mesh system offered via just an app .. this is very disapointing to say the least !
