Misiektt
Sep 01, 2022Aspirant
RBR850 DHCP doesn't work on MAC devices Firmware 4.6.9.11
Dear All, I really have strange and anoying problem, i factory reset rooter and recreated setup i have thus until the WiFI network name is different then before it works on all devices. When i chang...
Sep 01, 2022Guru - Experienced User
So only apple devices have an issue if you re-use an old ssid?
Did you go into the apple devices and force them to forget the network from before?
Misiektt
Not only apple, also Samsung Tv had problem, when i set up static ip everything is working but that doesnt solve the problem. I did erase previous setups on Mac and on iPhone that also dod not helped.
