Misiektt
Sep 01, 2022Aspirant
RBR850 DHCP doesn't work on MAC devices Firmware 4.6.9.11
Dear All, I really have strange and anoying problem, i factory reset rooter and recreated setup i have thus until the WiFI network name is different then before it works on all devices. When i chang...
Sep 01, 2022Guru - Experienced User
What is the name of the old SSID name?
I use a two word name with a space in between, WPA2 AES only and all my mac devices work fine. Been using same SSID name for past 20years though.
Misiektt wrote:
Dear All,
I really have strange and anoying problem, i factory reset rooter and recreated setup i have thus until the WiFI network name is different then before it works on all devices. When i change the name to the one I used before - most of devices connect but non of Apple product can. Strange thing is that even if i set Orbi to ap mode same situation happens. Please help. This is really something that should not be hapenning on that kind of product.
- MisiekttSep 01, 2022AspirantThe name is TurboWifi
- FURRYe38Sep 01, 2022Guru - Experienced User
Wouldn't think there is anything wrong with that.
What happens if you try Turbo Wifi with a space in between?
- Blanca_OSep 06, 2022NETGEAR Employee Retired
Hi Misiektt,
Are you still experiencing this? We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team- MisiekttSep 12, 2022Aspirant
Yes i still have problem with very very expensive Orbi system.
