Misiektt
Sep 01, 2022Aspirant
RBR850 DHCP doesn't work on MAC devices Firmware 4.6.9.11
Dear All, I really have strange and anoying problem, i factory reset rooter and recreated setup i have thus until the WiFI network name is different then before it works on all devices. When i chang...
Sep 01, 2022Guru - Experienced User
What is the name of the old SSID name?
I use a two word name with a space in between, WPA2 AES only and all my mac devices work fine. Been using same SSID name for past 20years though.
Misiektt wrote:
Dear All,
I really have strange and anoying problem, i factory reset rooter and recreated setup i have thus until the WiFI network name is different then before it works on all devices. When i change the name to the one I used before - most of devices connect but non of Apple product can. Strange thing is that even if i set Orbi to ap mode same situation happens. Please help. This is really something that should not be hapenning on that kind of product.
Misiektt
The name is TurboWifi
- FURRYe38Sep 01, 2022Guru - Experienced User
Wouldn't think there is anything wrong with that.
What happens if you try Turbo Wifi with a space in between?
- Blanca_OSep 06, 2022NETGEAR Employee Retired
Hi Misiektt,
Are you still experiencing this? We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Blanca
Community Team- MisiekttSep 12, 2022Aspirant
Yes i still have problem with very very expensive Orbi system.
- FURRYe38Sep 12, 2022Guru - Experienced User
Is the RBR connected to same ISP Modem/router in AP mode as well?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satelliteWhat channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Is Wifi Private Address disabled on ALL Apple devices?
