Misiektt
Sep 01, 2022Aspirant
RBR850 DHCP doesn't work on MAC devices Firmware 4.6.9.11
Dear All, I really have strange and anoying problem, i factory reset rooter and recreated setup i have thus until the WiFI network name is different then before it works on all devices. When i chang...
ekhalil
Sep 07, 2022Master
Misiektt wrote:...... Strange thing is that even if i set Orbi to ap mode same situation happens..........
If Orbi works when you set it in AP mode then for sure you have another router in the network, and DHCP issues are very likely to happen in a double NAT networks.
What is the model of the modem/router to which Orbi is connected?
- MisiekttSep 12, 2022AspirantToday after power outrage again all bad happend. Apple devices stopped connecting to wifi. I change the whole network set orbi in rooter mode change ip address to be different and nothing. This rooter should be proffesional one and ots just not working with apple devices. Same time every time no
Dhcp address.- FURRYe38Sep 12, 2022Guru - Experienced User
Is the RBR connected to same ISP Modem/router in AP mode as well?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Is Wifi Private Address disabled on ALL Apple devices?
Dhcp address. - ekhalilSep 12, 2022MasterYour network needs to be correctly configured for Orbi to work properly.
Please make sure that you only have one DHCP source, one NAT machine, one router,… and all will work.
