Chuck_M
Feb 16, 2023Mentor
RBR850 DHCP Options in Advanced Setup
I have recently been playing around with Pi-Hole running on a mini-pc on my LAN. It works great with Orbi simply by replacing the DNS IP with that of the Pi-Hole server. No more ads and faster brow...
Chuck_M
Feb 16, 2023Mentor
Thanks, I will give that a shot... do you have any idea what those options above are for?
Feb 16, 2023Guru - Experienced User
Some ISP's require option 60/61 to work with their equipment.
Which NETGEAR routers support DHCP option 60 and 61? | Answer | NETGEAR Support
