fbietlot
Jan 05, 2024Follower
RBR850 disassembly (to get back screw)
One of the mounting screw of my RBR850 is "lost" in the routeur. I would like to disassembly 'open the case) of the router to get it back. Is there any hidden screw ? How can I safaly open the rou...
Jan 05, 2024Guru - Experienced User
If you look at the back cover down at the bottom there is a press tab that you can press to make the back cover slide off, then this would reveal the screws to the front cover. Try to take these covers off first to see if the loose screw will come out.
CrimpOn
Jan 07, 2024Guru - Experienced User
Any hint on how to open the RBR750 case?
- FURRYe38Jan 08, 2024Guru - Experienced User
I don't. Wondering if SLK-Purdue might know?
