sawitt76
Jan 15, 2023Aspirant
RBR850 DNS Masquerade
I have a new RBR850 with fw V4.6.14.3_2.3.12. I have configured the DHCP dynamic address pool to be 192.168.1.50 thru 192.168.1.254. I'm using the address reservation feature to assign 'static' IP ad...
- Jan 23, 2023
I installed the dnsmasq package on a linux server I have and relieved the Orbi of DHCP and DNS duties. Its working great, and I'm happy.
sawitt76
I do, of course, realize that I can create a hosts file containing this information for each of these hosts, but why do that if the router can do it?
Thanks...
- microchip8Jan 16, 2023Master
Masquerading is not possible on stock NETGEAR firmware. I don't know on Orbi devices, but using a "normal" router (RAX43 and R7800) it serves both as a DHCP server and DNS resolver for my devices. On my desktop/laptop, all I have to do is add 192.168.1.1 to /etc/resolv.conf and don't worry about DNS. The router takes care of that (I use NextDNS on the router)
- CrimpOnJan 16, 2023Guru - Experienced User
Alas, Orbi routers DNS do not resolve "local hosts", much less automatically add devices to a table. It appears there are only two work arounds:
- Create host files on local machines. (Probably not very many will need a host file. 99% of the devices in the home do not even have a user interface.)
- Point the Orbi DNS at a local DNS server which has the capability. Pi-hole, for example, provides the ability to create DNS records and CNAME records. Here's a sample:
- sawitt76Jan 16, 2023Aspirant
Thanks for the information, I was pretty sure the Orbi didn't support Masquerade, but thought I'd ask in case I was missing something. This is my first mesh router system and in the past I've always bought routers that would run OpenWRT so I've gotten a little spoiled. I'll probably set up a local DNS server then and be happy.
