sawitt76
Jan 15, 2023Aspirant
RBR850 DNS Masquerade
I have a new RBR850 with fw V4.6.14.3_2.3.12. I have configured the DHCP dynamic address pool to be 192.168.1.50 thru 192.168.1.254. I'm using the address reservation feature to assign 'static' IP ad...
- Jan 23, 2023
I installed the dnsmasq package on a linux server I have and relieved the Orbi of DHCP and DNS duties. Its working great, and I'm happy.
sawitt76
I do, of course, realize that I can create a hosts file containing this information for each of these hosts, but why do that if the router can do it?
Thanks...
microchip8
Jan 16, 2023Master
Masquerading is not possible on stock NETGEAR firmware. I don't know on Orbi devices, but using a "normal" router (RAX43 and R7800) it serves both as a DHCP server and DNS resolver for my devices. On my desktop/laptop, all I have to do is add 192.168.1.1 to /etc/resolv.conf and don't worry about DNS. The router takes care of that (I use NextDNS on the router)
- CrimpOnJan 16, 2023Guru - Experienced User
Alas, Orbi routers DNS do not resolve "local hosts", much less automatically add devices to a table. It appears there are only two work arounds:
- Create host files on local machines. (Probably not very many will need a host file. 99% of the devices in the home do not even have a user interface.)
- Point the Orbi DNS at a local DNS server which has the capability. Pi-hole, for example, provides the ability to create DNS records and CNAME records. Here's a sample:
- sawitt76Jan 16, 2023Aspirant
Thanks for the information, I was pretty sure the Orbi didn't support Masquerade, but thought I'd ask in case I was missing something. This is my first mesh router system and in the past I've always bought routers that would run OpenWRT so I've gotten a little spoiled. I'll probably set up a local DNS server then and be happy.
- McLongJan 16, 2023LuminaryI've had good results running a pihole with FTL DNS resolver and Orbi 850 as router.
