giometrix
Feb 09, 2021Aspirant
RBR850 Does not accept 5ghz connections . All 5ghz connections go to satellite
RBR850 Does not accept 5ghz connections . All 5ghz connections go to satellite (RBS850), regardless of distance . Distance between router and satellite is about 17 feet . Size of house is about ...
Feb 09, 2021Guru - Experienced User
Also there is newer FW available as well:
giometrix
Feb 10, 2021Aspirant
I installed the latest firmware and unplugged the satellite . No dice , no 5ghz connections on the router .
I also used the airport utility on my iPhone and I do not see any signal with the channel in using for 5ghz.
- FURRYe38Feb 10, 2021Guru - Experienced User
Sounds like your RBR maybe faulty and needs replacing.
