All41
Apr 15, 2020Aspirant
RBR850 does not allow POP/SMTP email on WiFi
We just set up an Orbi RBR850 with three RBS850 satellites. All three satellites are connected via ethernet to the RBR850. The RBR850 has Firmware Version V3.2.10.11_1.2.12, which is current. Satelli...
CrimpOn
Apr 15, 2020Guru - Experienced User
There is a community forum specifically for the new AX product line: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
People who have these products typically follow that forum, rather then this one. You might get a more informed response by posting there.
You are entirely correct. There should be no need to open ports to perform POP or SMTP mail.
- All41Apr 15, 2020Aspirant
Thanks for the tip on posting to the Orbi (AX) forum. I've reposted my question there.
(Still can't enter the model number.)
