ClutchRaid
Mar 11, 2020Aspirant
RBR850 Double NAT Type error after 2 days
Recently purchased the Wifi 6 Orbi mesh wifi system. After 2 days, I'm no longer able to sign into routerlogin no matter how many times I try and change the password it still won't let me sign in. I ...
ClutchRaid
The RBR850 is currently on V3.2.10.11.
The RBS850 is currently on V3.2.10.11.
The Mfr of the modem is Arris.
The model # is SB6183.
Mar 11, 2020Guru - Experienced User
Also power OFF the Arris modem for 30 seconds then back on.
Be sure to clear out any PC network caches or power OFF the PC fully, including the power switch in back if there is one. Then back on after 30 seconds. If your using a game console like xbox, hold the front power button until the console shuts off. After the modem and RBR are back online, power ON the xbox and check NAT status under Settings/Networking. Port used should be 3074 and say OPEN.
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347. Reboot both RBR and wireless devices.
If this still fails, Please contact the forum moderator if your having problems with the lastest version of FW:
https://community.netgear.com/t5/Orbi-AX/ORBI-RBR850-frequent-disconnects-to-WoW-server/m-p/1871943/highlight/true#M1693
Thank you.
ClutchRaid wrote:The RBR850 is currently on V3.2.10.11.
- ClutchRaidMar 11, 2020Aspirant
I have not done a factory reset, but I'm also unable to sign in to routerlogin. It keeps making me reset my password then tells me the new password is incorrect.
- FURRYe38Mar 11, 2020Guru - Experienced User
Be sure to clear your browser cache first, exit the broser then relaunch. Try a different browser as well. I use Opera.
- ClutchRaidMar 12, 2020Aspirant
So I've done a factory reset of the Orbi system and still get the "Double NAT" error. I also rebooted the arris modem several times now and have rebooted the sattelite and router several times now. I'm able to access router login now after doing the factory reset.
