Rhoffman51's avatar
Rhoffman51
RBR850 Dropping Internet Connectivity
Recently (last few weeks) my RBR850 w/3 RBS850s would drop internet connectivity from my fiber modem (Orbi is the router).  What's weird is my Fire Sticks and Alexa's continue to stream, but phones, ...
  • Rhoffman51's avatar
    Rhoffman51
    Dec 11, 2024
    Thanks for your help!  I reverted the FW back to v.21 on all units (RBR and RBS), did a reset and set up the entire system again.  Ensured the "disable" radio button is selected for AU (and yes, my memory was a bit 'off') and everything is back to normal, like it should!  Thank you again for your help.  One question though, why would Netgear release a FW upgrade without conducting a Beta test to work out the bugs?  Seems to me a lot of people might 'dump' Netgear and go to another system because of the issues they were having that could have been avoided.  I almost did!
