Zweiklang's avatar
Zweiklang
RBR850 dropping network few times a day
Reporting back after some days of testing firmware 4.6.7.13 with my RBR850+RBS850 with Ethernet backhaul, running in AP mode with 1Gbit/sync fiber over Fritz!Box Modem.
Generally I can say the switching to pink every 24h is history, the whole network is way more stable now.
Nonetheless, I’m facing random complete WiFi dropouts, causing the entire network to be inaccessible for some minutes, even wired devices. Sometimes only restarting the Satellite is helping.
If the satellite is off, everything is perfectly stable, so I have to assume it’s the combo of AP and satellite that make the WiFi break down.
20/40Ghz coexistence is off, but that didn’t solve much. The logs are absolutely useless and don’t contain anything.
I would need help to get this fixed 😞
My Setup: ISP: Deutsche Glasfaser, Fiber (1GBit/s Sync), Router: Fritz!Box 5530RE, RBR850 + RBS850 (RBK853) in AP mode, Cat7 Ethernet Backhaul
  • FURRYe38's avatar
    Zweiklang wrote:
    Reporting back after some days of testing firmware 4.6.7.13 with my RBR850+RBS850 with Ethernet backhaul, running in AP mode with 1Gbit/sync fiber over Fritz!Box Modem. I presume the RBR and RBS were powered OFF for 1 minute then back ON after v.13 was applied or maybe was factory reset?
    Generally I can say the switching to pink every 24h is history, the whole network is way more stable now. 👍
    What is the distance between the router and 📡 satellite(s)?
    Is the RBS directly connected to the back of the RBR or is there a wall jack or LAN switch in between them?
    Does this still happen if the RBS is wirelessly connected instead of wired?
    What channels are you using? Auto?
    • Zweiklang's avatar
      Zweiklang
      I did a full factory reset after installing the firmware update.
      The Backhaul is wired directly, no switch or wall socket in between.
      Distance between the two devices is approx 10m, separated by a concrete floor and a few doors.
      Running the satellite on wireless Backhaul shows only a “poor” connection to the AP, that’s why I have refrained from that. Connected devices had a hard time to stay connected to the network.
      • FURRYe38's avatar
        And you do have the host routers wifi disabled..
        When the RBS was wireless did you see this same problem at the RBR other than the poor connection?
        Is this LAN cable between the RBR and RBS running thru the home walls or external cable?
        I'd be curious if you changed the RBRs transmit from 100% to 50% and see if same thing happens.
