charlie_sn
Jul 28, 2022Aspirant
RBR850 Dropping WIFI Devices
Hi all, I'm currently using the RRBR853 and sometimes random devices seem to drop connection to the Wifi and then you have to reboot them to work again, the Orbi is running in Router Mode and pl...
- Jul 29, 2022Since then nothing has dropped off and now I’m rooms where I used to get 300/400 it’s now 600 so I have no idea what happened but thanks
charlie_sn
I believe the Modem is a Huawei HG8310M but custom made for Openreach?
I'm using Cat6a
Have about 40 devices connected but 10 or so are on Ethernet
2750sqft
Recomended distance between the 3
Changed 2.4Ghz to 6 and it did it on another device
No other wifi networks
It's been up for 4hrs
Jul 28, 2022Guru - Experienced User
How many RBS do you have deployed?
What is the distance between the router and 📡 satellite(s)?
- charlie_snJul 28, 2022Aspirant
1 Router and 2 extenders
Unsure about the exact distance but its within the recomended
- FURRYe38Jul 29, 2022Guru - Experienced User
For the size of home you have you only need the RBR and 1 RBS deployed.
Would need to measure the distances between the RBR and RBS. Too close and this can cause problems.
I would turn OFF 1 RBS and see how things go.
- charlie_snJul 29, 2022Aspirant
I bought a 2 pack before a 3 pack and half the house wasn't covered with a 2 pack as the walls are very old and just brick and concrete even with 3 I can't get coverage outside and I just tried 2 again and coverage was very bad
