charlie_sn's avatar
charlie_sn
RBR850 Dropping WIFI Devices
Hi all,   I'm currently using the RRBR853 and sometimes random  devices seem to drop connection to the Wifi and then you have to reboot them to work again, the Orbi is running in Router Mode and pl...
  • charlie_sn's avatar
    charlie_sn
    Jul 29, 2022
    Since then nothing has dropped off and now I’m rooms where I used to get 300/400 it’s now 600 so I have no idea what happened but thanks
