VerneArase
Jun 04, 2021Apprentice
RBR850 email logs
Is Netgear ever going to fix their logging bugs? It's been over a year, and every log received continues to show that stupid loop at the end which I suspect may soft reset the router.
Jun 05, 2021Guru - Experienced User
VerneArase wrote:Is Netgear ever going to fix their logging bugs?
What do you mean by this 'loop" a the end?
Please post a capture of this email log please. Remove any MAC address from the capture please.
- VerneAraseJun 11, 2021Apprentice
Here's the last log sent to my Mac at 4:48 AM this morning:
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:48:47
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:46:31
[DHCP IP: (192.168.1.137)] to MAC address 12:34:56:06:F7:6B, Friday, Jun 11,2021 03:44:06
[DHCP IP: (192.168.1.137)] to MAC address 12:34:56:06:F7:6B, Friday, Jun 11,2021 03:43:52
[DHCP IP: (192.168.1.137)] to MAC address 12:34:56:06:F7:6B, Friday, Jun 11,2021 03:43:40
[DHCP IP: (192.168.1.137)] to MAC address 12:34:56:06:F7:6B, Friday, Jun 11,2021 03:43:22
[DHCP IP: (192.168.1.137)] to MAC address 12:34:56:06:F7:6B, Friday, Jun 11,2021 03:43:10
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:42:31
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:40:20
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:37:18
[DHCP IP: (192.168.1.151)] to MAC address 12:34:56:D3:87:D0, Friday, Jun 11,2021 03:35:11
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:34:20
[DHCP IP: (192.168.1.122)] to MAC address 12:34:56:00:3F:5B, Friday, Jun 11,2021 03:31:27
[DHCP IP: (192.168.1.15)] to MAC address 12:34:56:FB:0D:D5, Friday, Jun 11,2021 03:31:22
[DHCP IP: (192.168.1.15)] to MAC address 12:34:56:FB:0D:D5, Friday, Jun 11,2021 03:30:52
[DHCP IP: (192.168.1.15)] to MAC address 12:34:56:FB:0D:D5, Friday, Jun 11,2021 03:30:24
[DHCP IP: (192.168.1.6)] to MAC address 12:34:56:A5:4A:2A, Friday, Jun 11,2021 03:29:28
[DHCP IP: (192.168.1.3)] to MAC address 12:34:56:33:59:1C, Friday, Jun 11,2021 03:25:57
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:23:50
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:22:28
[DHCP IP: (192.168.1.120)] to MAC address 12:34:56:E8:E5:BE, Friday, Jun 11,2021 03:21:53
[DHCP IP: (192.168.1.101)] to MAC address 12:34:56:22:27:09, Friday, Jun 11,2021 03:21:42
[DHCP IP: (192.168.1.100)] to MAC address 12:34:56:22:26:E1, Friday, Jun 11,2021 03:21:37
[DHCP IP: (192.168.1.141)] to MAC address 12:34:56:C2:C3:E5, Friday, Jun 11,2021 03:21:13
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:18:29
[DHCP IP: (192.168.1.7)] to MAC address 12:34:56:15:66:70, Friday, Jun 11,2021 03:17:46
[DHCP IP: (192.168.1.142)] to MAC address 12:34:56:D8:2C:17, Friday, Jun 11,2021 03:17:23
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:16:14
[DHCP IP: (192.168.1.15)] to MAC address 12:34:56:FB:0D:D5, Friday, Jun 11,2021 03:15:51
[DHCP IP: (192.168.1.15)] to MAC address 12:34:56:FB:0D:D5, Friday, Jun 11,2021 03:15:05
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:13:46
[DHCP IP: (192.168.1.139)] to MAC address 12:34:56:AB:BC:C9, Friday, Jun 11,2021 03:12:05
[DHCP IP: (192.168.1.151)] to MAC address 12:34:56:D3:87:D0, Friday, Jun 11,2021 03:09:56
Friday, Jun 11,2021 03:08:25
Thursday, Jan 01,491926 -6:00:00
Thursday, Jan 01,491926 -6:00:00First off, there's those stupid time stamps at the end of each log line entry vs. the beginning, and the reverse chronological order is off-putting.
Secondly, look at all those duplicate DHCP entries for :6b, :c9, and :d5.
And thirdly - the real issue - the logs always seem to end with a loop of invalid time stamps which I suspect is the RBR850's attempt to format a date of zero.
(These are not real MAC addresses - the OIDs have been changed to protect the innocent - and to comply with apparent forum guidelines about posting MAC addresses - though if I got into your system I could get all the MACs in the system using the subnet mask and my address by ping sweeping the address range and doing ARP lookups.)
-- Verne
- FURRYe38Jun 11, 2021Guru - Experienced User
Ya I enabled email on mine last week. I saw same long ending data, then all subsequent emails after that were small and limited. I set mine to email me every hour....
- larryindublinJun 11, 2021Luminary
I've seen the exact same thing on my RBK753 unit logs. And I opened a ticket when I first got my unit and heard nothing back. Since out of warranty. Honestly I just turned off logs as I've rarely needed them - still would seem to be any easy fix...
