Babsan
Mar 09, 2021Initiate
RBR850 Ethernet ports stop working
Hi Community, I'm having some weird issues with my ORBI RBR850, FW v3.2.16.22, and the ethernet ports. I'm connecting with a home built PC using an ASUS ROG Strix Z490-A-Gaming motherboard (l...
Chuck_M
Mar 09, 2021Mentor
You may want to troubleshoot by seeing if you have another ethernet equipped device to plug into that port and see if the issue is in your NIC and not the Orbi. Just because a PC says it is disconnected, doesnt necessarily mean it is the router.
It is also possible that your NIC card is destroying the ports -- perhaps by stray voltage.
- BabsanMar 10, 2021Initiate
Hi Chuck_M,
Thanks for the reply and tip! I'll check later today and see if it works with another device - I really hope it isn't the NIC destroying ports by any means as you suggest, but I'll soon find out!
