Babsan
Mar 09, 2021Initiate
RBR850 Ethernet ports stop working
Hi Community, I'm having some weird issues with my ORBI RBR850, FW v3.2.16.22, and the ethernet ports. I'm connecting with a home built PC using an ASUS ROG Strix Z490-A-Gaming motherboard (l...
RudyP2
Feb 16, 2022Aspirant
I apologize. I have firmware version v 4.6.3.16
Feb 16, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
Be sure your using good quality LAN cable. CAT6 is recommended.
Might give this a try:
- RudyP2Feb 16, 2022Aspirant
The factory reset has been performed and is effective for a month or so, but the problem has reoccured again.
- Chuck_MFeb 17, 2022Mentor
The challenge is to determine if the problem is with the PC NIC or the Orbi Port -- or perhaps another device that is connected to a port on the Orbi.
Questions:
1. Do you have any other hard wired ethernet devices pluged into the Orbi ports?
2. Have you checked/replaced your cables? What kind of cables are you using between device and Orbi?
3. The device that keeps failing, is it a laptop, pc, etc? Details?
