rapshank1882's avatar
Oct 30, 2023
RBR850 Factory reset?
Hi Orbi guru's...
I have had my RBR850 and two RBS850's for a couple of years now and all is good.
My question for this evening... Should I perform a factory reset as good practice after numerous FW updates? Similar to PC or Android, when wiped clean they are snappier, faster and clears out old files etc.
Does the same apply to the RBR850 family or should I keep to the old adage, if it ain't broke, don't fix it?
Thanks!
  • If it ain't broke, don't fix it.
    Make a backup of the configuration any time there is a significant change.  That way, if a Factory Reset should become necessary in the future (when things are not working!), you have the potential to avoid a lot of tedious setup by restoring the configuration file from the backup.
  • CrimpOn's avatar
    CrimpOn
    • rapshank1882's avatar
      rapshank1882
      Tutor
      Thanks, chaps! I'll refrain from curiosity getting the better of me 🙂
      • FURRYe38's avatar
        Can always stop by here in the forums and ask questions prior to doing something.
        Have fun.
