mrwkbrdr
Nov 09, 2019Star
RBR850 fails FW update
RBS850 FW updated to 3.1.6.11 RBR850 fails to update, stuck on FW 3.1.5.23, it try's to download the FW and then says update failed. I paid $699 for a product that won't complete a FW update. N...
Nov 10, 2019Guru - Experienced User
Please contact Christian_R
This version is up on the beta forum and he can help you get the files you need.
You can connect to the RBS and directly update the RBS using its web page.
mrwkbrdr wrote:RBS850 FW updated to 3.1.6.11
Netgear case # 41906990
No one at NG knows anything about this new RBK852, maybe NG should not release a product they are unable to support.
