miller1975
Aug 13, 2021Tutor
RBR850 Firmware update No Internet
I have my RBR850 set up as an access point, when I check for firmware updates I get the status of "No Internet". I am guessing I need to open a port on my router, does anyone now what port it is or i...
Aug 13, 2021Guru - Experienced User
No. No ports needed.
How do you have the RBR connected to the host router?
miller1975
Aug 14, 2021Tutor
Thanks for the reply, yes its directly connected and all works fine apart from I have to do a manual firmware update
- FURRYe38Aug 14, 2021Guru - Experienced User
Be sure you have AP mode set up well:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I just had mine in AP mode. Manually updated it to v4 yesterday. I'm back in router mode today.
