spjgriw
Mar 24, 2021Aspirant
RBR850 firmware updates - service unreachable and manual updates fail
I have the orbi wifi 6 mesh system, model number RBR850. When trying to update firmware I just get the message "service unreachable and manual updates fail" If I download the update files and...
- Mar 25, 2021
NG meantioned to me that v12 was never intended to be up on the update service. Next major one should be.
Please mark you thread as solved so others will know.
Thank you.
Mar 24, 2021Guru - Experienced User
https://community.netgear.com/t5/Orbi-AX/Online-Firmware-Update/m-p/2074761#M13561
What version of FW are you using currently?
What browser are you using to apply the v12 manual FW files?
