rtrueman
Mar 24, 2021Aspirant
RBR850 Firmware V3.2.17.12_1.4.14
I manually updated my RBR850 and Satellite with the 3.2.17.12 firmware and having random disconnects since. Anyone else? This is the first time I've run into issues in the 6+ months that I've used it...
rtrueman
Thanks for the reply! I've rebooted, but not reset and setup from scratch. Is that really needed for every firmware upgrade? Yikes! No, the traffic meter is off (double-checked to make sure). I'm connected directly to my Verizon FIOS ONT.
Mar 24, 2021Guru - Experienced User
Sometimes yes.
Is there any router built in to the ONT or is it just a ONT only?
- rtruemanMar 24, 2021Aspirant
Okay, I'll rebuild if it keeps happening. It shouldn't be too bad.
I don't know about the ONT. I assume so as it's working without the cable router. We had Verizon make changes to the ONT years back as we weren't using the cable boxes and I purchased my own router. I didn't realize it worked without the router until I mistakenly hooked up the Orbi system, got it working, and realized the Verizon modem was sitting on the kitchen table. Oops!
- FURRYe38Mar 24, 2021Guru - Experienced User
Well hopefully it's not needed.
Be sure to save off a backup configuration to file for safe keeping. Saves time if a reset is needed. :smileywink:
