HomeUserguy
Sep 19, 2022Aspirant
RBR850 Firmware V4.6.9.11 schedule broken
After upgrading to V4.6.9.11 the schedule I have for blocking site for the kids is off by like 3 hours. I have validated the NTP setting and the date /time. I have a rule to start at 20:59 (8:59pm) ...
Sep 19, 2022Guru - Experienced User
What time zone are you in?
Do you have Access Controls enabled or SPC?
Has a factory reset and set up from scratch been performed since last update?
HomeUserguy
Sep 20, 2022Aspirant
I know that is tech support 101 to reset things as I have over 20 years of IT and network exp đ
lets look at the following.
#1 100% working no issue before upgrade
#2 Firmware upgrade ---> still works but off by 3+ hours
#3 Time zone is set correct
#4 NTP is correct
#5 I am not resetting my router because it cant tell time đ and everything else works
#6 -5 eastern
To me there is a bug in the logic that is messing up the time validation (would be my assumption). It most likely is staying in GMT or another time and not honoring the time zone.
again, no issue before the upgrade..... Still works just off by a number of hours.
The problem just related to hours.... everything else works
- CrimpOnSep 20, 2022Guru - Experienced User
The logic is sound. Certainly appears that Netgear has "disimproved" the firmware, which puts customers in the typical awkward situation:
- Go back to the previous firmware version, which implies
giving up any actual improvements in the current firmware and
finding a way to keep Netgear from automatically upgrading the firmware,
or - Find a workaround to get manage the problem until newer firmware fixes the problem.
Perhaps deliberately set the activation time off by three hours?
Remain alert for potential issues, such as the three hour problem varying by day or month, or by time of day.
Check to see what effect new firmware has on the issue.
There are people on the forum who can pass concerns to Netgear support, although nobody on the forum has any direct influence on how Netgear responds to issues. (One might imagine an item appearing on the "List of Tasks" and some engineering manager determining when (or if) it will ever be assigned to someone to check out. Things like (a) how many customers does this affect? (b) isn't our goal to sell subscriptions to Parental Controls? When I compare this with the constant complaints of systems totally rebooting every day or dropping the WiFi signal several times a day...... well.)
If I had an 850, I would be love to replicate the issue.
- FURRYe38Sep 20, 2022Guru - Experienced User
Can you detail us set by setup process that you use to setup your scheduling configuration please. NG will need this so they can replicate this. Some of us have same series orbi and will help replicate to collect debug logs as well.
Please try a factory reset and setup from scratch on the RBR. Users have seen odd problems appear after a FW update. Factory reset resolved some of these problems.
What was the prior version of FW that it was working on?
Try reverting back to this version of FW.
#2 Firmware upgrade ---> still works but off by 3+ hours#3 Time zone is set correct
#4 NTP is correct
#6 -5 eastern
