alvin1123
Feb 22, 2022Initiate
RBR850 for separate IOT network
just wondering since the orbi 6E has an option for a separate IOT network, will you roll out the same function for orbi 6 as well? I have at the moment around 10 iot devices connected and total 20 de...
CrimpOn
Feb 22, 2022Guru - Experienced User
FURRYe38 wrote:
Orbi 6 doesn't have the HW for a separate IoT nework.
I do not think that hardware has anything to do with it. Since the first Orbi Pro, which has exactly the same hardware as the original Orbi, Netgear has had products with multiple SSID's and "separate networks." That WiFi 6E chip added to the 960E product has nothing to do with the 2.4G WiFi band used by IoT devices. In that regard, the 960E has the same hardware as the original Orbi and the AX products. The difference lies in firmware.
In terms of network performance, adding more SSID's to an existing WiFi channel reduces capacity. Each SSID generates management overhead in the form of beacon frames announcing, "Here I am." The 2.4G bands where IoT devices live already have the lowest capacity and most interference of any WiFi system. If some IoT devices are "dropping out", adding a separate SSID for IoT will not improve the situation.
My take is that companies "move forward" to develop new products which will give customers incentives to purchase replacements for their current equipment. Part of the attraction is new features.
We on the forum, of course, are not employed by Netgear and never hear in advance of product developments.
Mikey94025
Feb 22, 2022Hero
Comparing the Netgear website Product Datasheets for the Orbi products is a good way to see the hardware radio differences and numbers:
- Orbi AC, e.g., RBK53
- Simultaneous Tri-band WiFi
- Radio 1: IEEE®
802.11b/g/n 2.4GHz -
256QAM support - Radio 2: IEEE®
802.11a/n/ac 5GHz -
256QAM support - Radio 3: IEEE®
802.11a/n/ac 5GHz -
256QAM support
- Orbi AX, e.g., RBK853
- Radio 1: IEEE®
802.11b/g/n/ax
2.4GHz—1024-QAM support - Radio 2: IEEE®
802.11a/n/ac/ax
5GHz—1024-QAM support - Radio 3: IEEE®
802.11a/n/ac/ax
- Orbi AXE, e.g., RBKE963
- Simultaneous quad-band WiFi
- Radio 1: IEEE®
802.11b/g/n/ax 2.4GHz —
802.11a/n/ac/ax 5GHz —
1024-QAM support - Radio 4: IEEE®
802.11a/n/ac/ax 6GHz —
1024-QAM support
