MeGrimlock
Mar 10, 2020Apprentice
RBR850 Frequent Disconnects Starting March 9th AM EST
Yesterday 3/9, starting at about 6AM EST, my Orbi system is disconnecting my Nest Cameras and Thermostat and my work laptop every 10-20 mins or so. I have about 20 devices connected to my mesh syste...
Mar 10, 2020Guru - Experienced User
What happens if you disable AX mode on the RBR?
Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Under Advanced Tab/Advanced Settings/Wireless Settings. Save settings and reboot the router and satellite(s).
What generation is your NEST thermostats? I have 1 1st gen and 1 3rd gen. I did notice that my 3rd gen disconnected the other day. I had to have it reconnect...
